How to create What's On events
Use the form to add shows, meet-ups, charity rides, sporting events and anything else to the What’s On calendar, and you can let people know if you’re interested or planning to go as well.
Add an event by creating a new topic and selecting Create event from the Options (+) menu.
Add the event details to the form and save it. Your new event will appear on the calendar automatically.
To create a pin on the events map, use the Add Location button. There is a location field on the Create event form but the map does not use that location data. You must use the Add Location button.
You can see all upcoming event locations by selecting the Map view. Select a pin to go to the event post.
Topic created for events will be closed 48 hours after it finishes. Pins are removed from the events map when the topic is closed.
Events in the calendar are colour coded based on the tag you select but pins on the map are not.
Red = Shows
Yellow = Meet-Ups
Orange = Charity Rides
Cyan = Other Events
Blue = Sporting Events
