Check your VIN numbers.
New Recall/Safety Bulletin regarding Modern Classics Alternator connector. It appears that the Alternator connector clip that was fitted has now been superseded fith this new bulletin. The connector is removed completely and hard wired.
I have taken this from the Triumph Technical Information website which does not allow you to print the bullitin. I have with screen grabs and Adobe InDesign produced a copy of the document. A bit time consuming but it works. Appologies if you find any mistakes.
Safety Recall Notice TSB 641.pdf (3.8 MB)
