OEM Bobber handlebars on Bonneville T100
Is it possible to install the Bobber handlebars to the 2025 T100 (or T120) using the stock brake hose from the T100?
Anyone here done it and do you have pictures? Just want to make sure it is the right thing for me, before ordering the handlebars. :blush:
Thanks
Bobber and T120 has one inch diameter bars, are the T100 the same, or 7/8 inch?
My T100 is also with 1 inch handlebars.
When I bought my Speedmaster I had dealer put on the Bobber bars with the corresponding brake and clutch cable.
Later, when I wanted a more upright riding position I just swapped to the T120 bars. The cables were a little too short but didn’t casue problems.
So, from my experience, changing Bobber to T120 bars worked. I assume going the other way would also work, you would just end up with slightly too long cables. There is probably a way to adjust the cable routing to take up a little bit of the extra slack to make it look less ugly.
