Greetings all,
I’ve broke the small wire that goes inside the headlight. I need to remove the black shroud to get at the motherboard. I’ve removed the 4 screws but it won’t budge. Is there some trick I’m missing?
Greetings all,
Hi pdj. Welcome to the forum.
Thanks mate!
Take the torx head out holding the metal clip, could be a fixing behind there too. There may be some sort of sealant on there too, I’ve no experience with it but being electrical, good chance its sealed.
Thanks also for spotting that we didn’t have a Speed Twin section! We do now. ![]()
Have you taken the chrome trim off the front? Looks like a screw under it at the top (near the 11)
Hi and welcome…
Thanks all,
I can’t get the black cover off. It’s definitely glued on there good. I really don’t see any alternative except getting out my Dremel and cutting a hole in it so I can reattach the wires.
