I have lowered the Bonny fitted new rear shocks and also lowered front forks now bike stands to upright on side stand does anyone know of another side stand that will fit
Hi and welcome to the forum ![]()
Not sure about the sidestand but someone may know
Hi and welcome. I would think that you will need to shorten the side stand, others may have another solution.
You can get adjustable side stands I believe (but have never used one). Some people get theirs cut and welded to shorten it as well - obviously that’s a permanent thing, so maybe get a spare one and do that in case you want to return the bike to standard to sell etc at any point.
I expect that the cut and weld option would be best. I haven’t looked at mine to check, but I suspect that fitting a different stand would be likely to give problems with the sidestand cutout switch.
As said above, find a used side stand, and shorten it and weld.
The tricky part will be to determine the length. To achieve that, I would put the tyres on wooden blank. If it’s okay, remove the thickness of the blanks from the new side stand.
Thank you all good now
What did you do?
Side stand cut out 20mm and welded thank you.
