In 1912, the young Veloce company were busy making a 2½ h.p. motorcycle for the discerning gentleman.
The Motor Cycle popped in to the factory in Fleet Street, Birmingham (UK) and took the bike out for a road test. This is their report, published in the magazine 113 years ago today:
On a recent visit to Birmingham we accepted an invitation of the Veloce Co. to sample the running of one of their 2½ h.p. machines. The day was not auspicious, for" all the morning it poured with, rain, and in the afternoon dried up just enough to give the tramlines and setts [1] a treacherous coating of grease. However, the low build and light weight of the machine emboldened us to make a start, so the low gear was engaged and the machine given a push, whereupon the engine started to fire slowly , so slowly, in fact, that we were able to depress the gear pedal to the free engine position with great ease and then mount the machine in comfort and tuck in coat tails, etc., before engaging the clutch. The gears are operated by a rocking pedal with the left foot, pressure backwards engaging the low ratio, and forwards the high.
The Low Gear Seldom Needed.
On letting in the low gear the machine slid gently away, and after slight acceleration in went the high without a suspicion of jerk. As far as power was concerned the low gear need never have been used, but we found it a great, blessing in the thick traffic and on the greasy roads. A slight sing in the gears was noticeable but not unpleasant, whilst the exhaust and the valve timing gear are beautifully quiet.
Through seas of mud we churned our way all morning, and though the particular machine lent us was fitted up in T.T. style with only regulation width guards they were so well arranged that the mud thrown up was not excessive. In the afternoon we had a practical demonstration of the advantages of forced lubrication, for on slippery roads in thick traffic one is relieved of all trouble in this direction by an occasional glance at the indicator, we noticed two points in particular, one was that the outside flywheel permitted the engine to run very slowly, and although it revolves in a contrary direction to the road wheels the effect is not noticeable; in fact, the machine is very steady in grease. Secondly, that throughout the heavy rain there was no suspicion of belt slip, which may be accounted for by the large geared-down engine pulley. The gear ratios used were 5½ to 1 and 9½ to 1 approximately.
The Works Organisation.
On returning to the works Mr. Taylor showed us round, and we were delighted with the jigs and tools in use and the careful way in which the parts are turned out. For the present year the 70 x 76 mm. engine only, will be manufactured, but it is possible that a larger model also will be marketed in 1913. Before leaving the works in Clissold Place we were introduced to Mr. Nat Woods, of Christchurch, New Zealand, who had just placed a considerable order for motor cycles with Veloce, Ltd.
