Well, I don’t want to pre-empt my next big data dump…but, for me, the requirements and parameters may be different to others…
You say “suits”; is that because you’re racing or in full leathers? If so, we are going to disagree simply because the protection you require will be different from mine due to totally different riding situations. Not good, bad, better, or worse …just different. Apologies if Ive misunderstood that
I LIKE the ease of use that the Helite offers, especially after an off. Provided all seems ok with a quick visual check and the slow air release as it deflates, you can reload your vest with a £20 spare canister yourself at the roadside and you’re good to go.
Similarly with the Klim/Ixon jackets, albeit the canister is nearer £70 a throw.
I believe that the Dainese needs to be sent off for a reset, at a cost of £215ish… That’s rather a lot.
I know we are taking about worst case scenarios, with all these in such instances, it may well be the least of your concerns when it’s saved your life… However it is, for me, a tick in the “cons” column to have substantial cost and specialist check each time.
The other issue, and a significant issue for me, which few seem to address in any detail, is the coverage when deployed.
As said, in my opinion, the Helite offers by far the most coverage, followed by the Klim/Ixon…
The Dainese for me misses the mark as it seems to offer little to no neck protection, or indeed head immobilisation.
I would have thought that preventing hyperextension of the neck is surely a must have!? The Dainese doesn’t have it. Not that I can see or ascertain from any images or specs.
Its as simple as that for me. Protection (or lack of) at less user friendliness rules it out.
*I will happily caveat this with the fact I have tried to read up on stats for what injuries motorcyclists actually sustain, and with that in mind whether airvests have a positive outcome. I have my opinion based on what I’ve read. However and Specifically re hyperextension of the neck I’ve not been able to find…maybe Dainese have it right and the other brands are needlessly incorporating that aspect in to their designs? I can not say. But my lay person POV wants that neck protection.
I have other reasons, but they are very personal to me - re weight, fit, etc. But the above are reason enough to rule Dainese out.
Alas, ditto for the Alpinestars Tech 5…
