Hello,
Just joined the forum and just bought (last week) an 05 Daytona 955i.
Been out for a couple of rides to give it a bit of a shakedown and noticed a flat spot around 5k, it has an after-market can/exhaust, so thinking it might be that.
I know it was a common fault with the earlier models, but wanted to check if anyone else has had a similar problem with a gen 2?
Thank you,
Johnny
Hi and welcome. Can’t help you, but I’m sure someone can.
Hi and welcome @Johnny
I have a gen 1 Daytona T595 and have seen this issue on and off. I know you asked about gen 2 owners but there are a few things I have tried that might help, and I don’t really know if just one of these contributed or fixed the issue last time.
- Replace stale fuel
- Split or perished vacuum hoses
- Replace fuel filter and check fuel hoses
- Check ECU for errors (I use TuneECU)
- Remap for aftermarket exhaust or put an original exhaust on to eliminate this as a potential cause
- Check/reset Idle Air Control Valve (IACV)
- Reset Throttle Position Sensor (TPS)
Good luck
Hello Geoff,
Thank you for taking the time to give this insight - appreciate your help mate.
Welcome to the forum Johnny. I can’t advise you but would be interested to see how you get on fettling it?
Hi and welcome to the forum
Welcome, Bienvenue! Geoff nailed it. Aftermarket exhaust means the ECU version map needs to be checked.
