Leaking oil cooler due to getting very hot
Hi I’ve recently done a tour on my triumph 900 scrambler from Caen in France down to La Rochelle the weather was very hot 35 degrees most days then back up to Caen via La baule and the Normandy coast then back home to Leicester on my return noticed an oil leak on the cooler after closer inspection it’s Leaking across the cooler but I’ve also noticed how close the exhaust is to the cooler this can’t help has anyone else had this issue thinking of moving the cooler to the other side of the frame or is there an alternative cooler thanks Matt
Hi and welcome. I’ve not owed a scrambler, but many triumph twins both 900 & 1200 variants and I have never had an oil leak that you have mentioned.
