I recently replaced the wheel bearings and seals on my 2018 Speedmaster and I found the OEM ones were NSK brand and I could get these for 1/3rd the price from Simply Bearings (https://simplybearings.co.uk). I made two purchases and the free delivery option came next day by 1st class post. ![]()
The same wheel bearings parts are used across most of the range of modern Triumphs so I thought it would be useful to show the OEM part number and link to the exact item I bought. Assuming OEM bearings are standard tolerance sort, not some special ones, then the bearings should be identical items. The seals are of a random brand but same twin-lip construction.
| Triumph Part | Alternative |
| Front wheel | |
| T3800702 | Bearing NSK-6004DDU |
| T3600703 | Seal 30x42x7mm (1mm deeper than OEM but lots of space on my wheel) |
| Rear wheel | |
| T3800703 | Bearing NSK-6204DDU |
| T3600701 | Seal 28x47x7mm |
| Sprocket carrier | |
| T3800029 | Bearing NSK-6205DDU |
| T3600073 | Seal 35x52x6mm |
