Note: The contents of this post first appeared in ‘What You Been Doing With Your Triumph Today’
Following this will be new posts in the saga.
On way home from holiday I had engine temperature warning light come on whilst stuck in traffic, so I resorted to killing engine at stops until on open road where things seemed fine. Sure enough, when home found fan wasn’t coming on, so today I set about investigating.
Following trusty Haynes manual I first checked the fuse, which was fine, then got at connector under tank, but not having handy cables I thought that instead of putting 12V from battery onto fan wire to test it, I’d be easier to get TuneECU to do fan test and look at voltage with multimeter. Sure enough, I could hear relay click and 12V appear on connector so decided problem was with fan, bugger, a new one costs £250.
Even more of a problem was actually getting at fan, I could unbolt it easily (thankfully no rusted fasteners) but to get it out I would have to take radiator off. So I drained the coolant system and tried wrestling it out. Not meeting success I resorted to subscribing to Triumph service manual to see what the ‘correct’ procedure was. Found out that was to remove the engine cradle, the same cradle which I had jack under supporting bike. ![]()
In the end I resorted to sacrificing blood from my knuckles whilst using three small screwdrivers like mini tyre irons to get coolant hose off engine. Only then with radiator and fan off I decided to double check it by connecting up to battery, and the fan worked! And to add to my stupidity, I had fan resting on seat and the blades put a slash in the coccyx cushion. (I have a spare for an old seat fortunately).
So, it seems like fan problem is a high resistance in the wiring or relay which are probably very inaccessible, so it’s time for a stiff drink and return to this tomorrow…
Forks are out, because I’d decided to referb them and do headstock bearings. Also on the list to do is chain and sprockets as the 1000 mile holiday had produced 20mm extra slack so chain must buggered (done 25k miles so not too bad).
The next day…
More bike dismantling…
Service manual also said to get battery compartment lid off, which was rather daunting being as there’s 7 sets of wires and connectors intertwined with it in various ways. As I started to untangle that I was thinking that I’d never get it back together no matter how many photo’s I took. However, it looked to me like the battery holder would come out without the lid so I checked Haynes manual and it implied it did, phew! Finally, after 2 hours I had sight of the relays, though only fingertip access in bowels of bike.
Think I found my radiator fan problem…
I’ve ordered a new relay but was worried how to clean up the socket.
Would love to spray in some solvent cleaner in, but all around there is ECU, regulator and ABS modulator, plus other relays which might not like that. So decided to just spray in some soapy water and use a toothbrush (about all I could get into the space). Relays seem to have dialectic grease on contacts so there’s probably muck stuck in the relay socket but I don’t know what I can do about that. Decided to just clean up old relay pins and put back in and out a couple of times to try and dislodge any crap.
Have ordered 3 new relays, as was thinking of a preventative replacement of the neighbours, but the wire bundle there is stiff and short and goes into an inaccessible connector (to the ECU I think). Will probably leave well alone
