ANYONE KNOW WHERE THERE IS A SWTICHED POWER PLUG ON THE STREET TWIN 900 2019 MODEL. wISH TO ADD A SAE CABLE FOR PHONE CHARGING.
NO I DON’T KNOW BUT IF YOU CAN’T FIND SOME YOU CAN HAVE A LOOK AT THE HEALTECH THUNDERBOX.
And Welcome by the way.
Hi and welcome…. I think @Vulpes might have a solution to answer your question. He will be along shortly. ![]()
I don’t think there’s a dedicated plug on the bike. If you don’t mind splicing in to the loom it’s generally the yellow wire running through the harness that’s switched. The easier (though not free) solution is, as @Hubaxe suggested, A Healtech Thunderbox. Easy to fit, and provides you with up to 5 connections.
Oh, and WELCOME!
Sorry can’t give an answer, but thought there might be a socket somewhere for the use of factory options like heated grips or din socket which are usually ignition controlled.
Anyway.
Welcome!
(Caps lock is over on the left somewhere BTW
Apparently Street Twins have a usb socket somewhere under the seat, but I’ve never looked for mine.
Hello,
I know that the Speed Twin 900 has a USB socket under the seat (strapped on top of the battery) and also it has an auxiliary power socket for extras such as the Din socket that is taped up and sited underneath the petrol tank. I believe the axillary one is always live, as it doesn’t go through the ignition it is think it is fused possibly marked as AUX on the fuse box.
Whether it is the same for a 2019 Street, I am not sure.
The general hand book for these models has the info about the fuses etc. its easily found online.
Hope this helps. D.L.
If you have a multimeter or something to plug in, test if it’s an after ignition plug.
