So any clues be great … 1998 trophy use it loads was out and about got home put in garage now won’t start . Nothing was wrong nothing happened parked in in garage then five days later nothing .It turns over smell petrol but nothing not α cough or α splutter any clues cheers
Getting electricity to the fuel?
no spark, no bang, no grin ![]()
Welcome Barry,
how can wee know? As said above it can be anything from fuse, relay, a cut cable.
I’d try to eliminate problems one after each other.
I’d start with removing the tank, to check if you have a spark removing one plug.
Then drop a little gas directly in the carb to check if the engine can run, etc etc.
Last time I did that process I successfully repaired a rideon lawnmower I bought broken. ![]()
