Triumph TT600 front bike pegs
I’m looking for a set of front pegs for a TRIUMPH TT600 2001. Triumph have no new stock, so I’m looking for either a breakers or someone on the forum that may have a couple. I believe the Left and Right pegs are the same handed.
Triumphs of this era were heavily design and manufacturing influenced by existing Kawasaki models. Have you tried getting second hand pegs from, say, a similar year ZX-6R or ZZR-600?
You might want to take measurements from your machine and then, perhaps, trawl around any local bike meets with a tape measure and ask permission from owners to measure the peg and hanger dimensions on similar looking bikes? After all, you need (ANY) pegs with two vital, matching properties for them to fit your machine :- the hanger bracket width, the spindle hole size. If you can get those ‘in range’ you might be able to get away with not necessarily having the correct spring location by doing away with the spring - gravity is your friend.
Good luck with your search.
p.s. https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/896072
You could try asking if they’ll measure a pair of these for you?
Thank you. I have one peg. So have just got to find a match. None on eBay etc but will look at different bikes from the same year.
Have you tried the breakers yards? D&K used to have a massive second hand spares department?
