If you’re using an iPhone or an iPad to access the forum you should know there is a bug in Apple’s Webkit that messes up the positioning of the elements of the reply window when the keyboard is opened.
Apple are working on a fix. We’re hopng it’ll be released in a week or two. I’ll let people here know as things progress.
In the meantime, if you haven’t upgraded your Apple device to iOS 26 or iPadOS 26, you may want to hold off for now.
I believe the bug was introduced with the beta 7 release. Not sure when that became available. I usually try the betas but not in this case as I didn’t realise I needed to select iOS 26 specifically. I assumed if you’re in the programme, you’re in the programme.
I don’t know what it is, but in the last month or so my ayephone has morphed into a slug… I had to grit me teeth using it, and it ain’t over filled or had too many apps on background refresh… I just think that Apple need to shift a few units and have uploaded iOS Sloth25
