Col_C
9 April 2023 12:05
21
So I’ll add to the game…
This has two answers, the tool has been modified.
What was its original purpose (which I no longer need) when the long allen key had the usual 90 deg end and was used in conjunction with the sleeve.
I’ve since re-purposed the long allen key, cut off the 90 deg end and provided a larger hex, the sleeve is no longer used. What do I use it for now?
No cheating
We have safely established @Iron ’s encyclopaedic knowledge of all things Triumph. To that we can now add lawnmowers. Where will it end, I ask myself?
Victorian surgery re-enactments?
@Col_C is it for incrementing 0.25Nm for the analy retentive?
Is it for attaching a thingymebob to a whatchamacallit?
Col_C
10 April 2023 08:43
27
That’s a possible description of use 2.
Is it a fork setting adjuster?
Col_C
10 April 2023 10:20
29
Original use is for adjusting something, not forks though…
Tappets without cam cover removal
AdieP
10 April 2023 14:12
32
Looks like it was an SU carburettor tool?
Col_C
10 April 2023 20:48
35
Idle mixture, but for which carb?
Col_C
11 April 2023 09:28
37
Correct.
For a car I had in the early 80’s.
The long allen key is now re-used along with extensions on a 1/4 drive socket set to access the clamps on the throttle body rubbers when doing a valve check on my Speed Triple.
In my best @Iron impression…
Over
Well done collective. Here’s a pretty easy one to settle your nerves, but for which bike? And what colour was it?
It’s for tightening your nuts and they were very very red.
Centifugal oil filter socket, Honda CG125, red…
