On today’s ride on by Bonneville Speedmaster I had the cruise control stop working, then I noticed the engine was running a bit rough which gradually deteriorated. Thinking now, the rough running was accompanied by a laggy throttle where it seemed to lose power, and upon giving it more throttle it ‘overshot’ and I had trouble maintaining steady running. I found a convenient place to pull over and the engine died once stopped at idle. Upon trying to restart, the starter would crank over but engine wouldn’t start.
There were no fault lights on the instrument panel and no error codes shown after checking with TuneECU and the OBD2 reader I carry. But that did show the battery voltage was only just over 6 Volts!
To cut a long story a little shorter, the battery was good, reading 13V, and the AA roadside assistance I had called removed my battery and connected in their own which also wouldn’t start the bike. Thing is, with ignition on, the instrument panel works, the fuel pump ran, and the full beam headlight would work fine. So seems a lot of the electrics have a good power supply but the bikes computer reckoned battery was in the 5-6V range.
Once bike and I were brought home by the AA I did a little experimenting and things seemed the same as before. Then the throttle solenoid had a seizure banging against the end stops and has now thrown an error code and stopped working. Fuel pump also doesn’t come on. Voltage according to CAN bus has now dropped even further to 5V, so that could be the cause of the above stopping working.
I’m hoping that there is not a fault with the ECU, just some corroded or broken connection. Another possibility is something like the throttle solenoid failing and causing a partial short, bringing down the voltage.
As my ‘workshop’ is a conservatory which is too hot from a day of sun I am going to wait until tomorrow before starting to dismantle bike for access to wiring. I will try disconnecting things like the throttle solenoid, and wiggling things to see if I can get the reported voltage to change, so giving me a clue to the problem area.
